yellowhusaberg Posted February 24, 2013 Share Posted February 24, 2013 hi,does any one have a spare fuel pressure regulator?it's the one on the bracket that the fuel pump and fuel filter is on under the rear of a coupe. Link to comment Share on other sites More sharing options...
spiney_norman Posted February 24, 2013 Share Posted February 24, 2013 It's not a pressure regulator, it's a pre-filter if that helps at all! Link to comment Share on other sites More sharing options...
yellowhusaberg Posted February 25, 2013 Author Share Posted February 25, 2013 thanks but i think it's a pressure regulator of some sort as it has a adjusting screw coming out of it.looking at it now i have a pre filter feeding into fuel pump into fuel pressure regulator into fuel filter into fuel line to the injection system.this is exactly as it shows it in the haynes manual? Link to comment Share on other sites More sharing options...
shaggy Posted February 25, 2013 Share Posted February 25, 2013 Can you see any number on the top of the part? It will probably be a Bosch part. If you can give me that number I can see if we have one at work. Link to comment Share on other sites More sharing options...
spiney_norman Posted February 26, 2013 Share Posted February 26, 2013 Like this one? Link to comment Share on other sites More sharing options...
mantasrme Posted February 26, 2013 Share Posted February 26, 2013 The bit with the adjusting screw is a damper to smooth the pulsing of the pump out, not that an rotary injection pump really pulses. They rust badly and often develop a leak. You can remove them with no difference to the engine running or performance I've done so many times on CIH, 20SEH, C30se and C20XE engines as the originals were not fit to reuse and replacements were not available. Link to comment Share on other sites More sharing options...
yellowhusaberg Posted February 27, 2013 Author Share Posted February 27, 2013 thanks for your help guys,think i will go down the route suggested by mantasrme and do away with it Link to comment Share on other sites More sharing options...
dazi240 Posted February 27, 2013 Share Posted February 27, 2013 Dr manta.........ouch Link to comment Share on other sites More sharing options...
Matthew Posted July 18, 2013 Share Posted July 18, 2013 I always thought it was there to keep the fuel pressure for some time so it's easier to restart engine. Common misconception? Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted July 19, 2013 Share Posted July 19, 2013 818542 9292585 FUEL FILTER 19E-20E ASCONA-MANTA/B 818545 90019987 FUEL FLOW VALVE ASCONA-MANTA/B Link to comment Share on other sites More sharing options...
OPEL PARTS GREECE Posted July 19, 2013 Share Posted July 19, 2013 I always thought it was there to keep the fuel pressure for some time so it's easier to restart engine. Common misconception? The fuel valve (under the car) is for normal flow and the pressure valve (near intake) is for the fuel pressure...... Link to comment Share on other sites More sharing options...
