Solid Lifters
conaero
Guys, before I go have a look at the book, can you tell me what is the procedure for swapping my hydraulic lifters for solid ones?
Obviously I have to set up the valve clearance but taking the rockers off etc????
It's a 1.9 CIH 8v engine.
Edited by conaero
Just takr the rockers off, remove the lifters and replace with the solid ones. Then set tappet clearances. I assume this is because of a cam swap? Be aware that the ramp profiles on the cam are different for solid lifter cams than hydraulic ones.
hth
Chris
if the cam thats fitted is a correct 1.9 item the followers will be solid type anyway now. only the 2.0 & above were hydraulic.
I disagree, I have three 1.9's and all of them are hydraulic..
according to my dealer parts book all 1.6 & 1.9 are solid. thats not to say that your engine has still got its original cam.early cams were a wear point anyway thats why they modified the later 2 litre ones to a different material/hardening .
also if you fit solid tappets to replace hydraulic ones you never seem to get a silent system anymore.& if you fit hydraulic to replace solid you get a super guiet but rough tickover engine.this is to do with the cam profile.i beleive solid grinds have a very slight clearance take up before they open the valve. i would also imagine that 1.9 cams are harder to find than 2 litre ones especially.so many 1.9 `s may have been replaced with 2 litre ones & hydraulic lifters. who knows. ????
