Thomas77GR Posted March 23, 2013 Share Posted March 23, 2013 Hello I've wired in a set of gauges (only voltmeter and temp meter at present with oil pressure to be next) but I've noticed that the temp does not rise above 60 when the thermostat is I believe the 82C type. I'm running a 2.0 L block with carb and a radiator off a 2.0L manta (so slightly bigger than the original 1.6L) I've checked the connections and appear fine. The car drives fine. any advice - should I worry? Quote Link to comment Share on other sites More sharing options...
Rapierdave Posted March 23, 2013 Share Posted March 23, 2013 Assuming the temperature gauge is reading correct it could be that the Thermostat is stuck open or more likely someone has removed the stat. Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted March 25, 2013 Share Posted March 25, 2013 As above. Faulty thermostat? Quote Link to comment Share on other sites More sharing options...
