nova-baz Posted May 7, 2013 Share Posted May 7, 2013 hi all ive got a mk1 cav fitted with a c20let engine i was using a manta 1.8 gearbox but wanted to run more power so have fitted a omega r25/28 gearbox problem is its a hydraulic system and need to fit a master cylinder but looks to be no space in engine bay as intake manifold looks to sit in the way! had any one fitted one if so how did you get round it? gheers gary Quote Link to comment Share on other sites More sharing options...
611 Posted May 8, 2013 Share Posted May 8, 2013 Hi Gary I dont know if this is much help but im going to be running a hydralic clutch on my A series and am using wilwood master cyliners with remote pots. Its a close fit :-) but should just clear ok http://www.theopelproject.com/wp-content/uploads/2013/04/IMG_20130428_153022.jpg Andy Quote Link to comment Share on other sites More sharing options...
nova-baz Posted May 8, 2013 Author Share Posted May 8, 2013 cheers andy think i will have to buy one a try! Quote Link to comment Share on other sites More sharing options...
Retro Power Posted May 10, 2013 Share Posted May 10, 2013 Just seen this! Here's how I do them if keeping a "normal" manta/ascona pedal box and servo: just weld an eye in place of the cable hook on the pedal and use a girling or wilwood (girling copy) master cylinder, 0.75" bore Alternatively, if you want to go non-servo, bias brake pedal box, you can use a triple cylinder box designed to fit a mk1 escort, but you need to remove (de-spotweld) the original reinforcer from the inside of the bulkhead: Quote Link to comment Share on other sites More sharing options...
Retro Power Posted May 10, 2013 Share Posted May 10, 2013 Quote Link to comment Share on other sites More sharing options...
Retro Power Posted May 10, 2013 Share Posted May 10, 2013 PS lastly, you might want one of these if you are using the omega box: Quote Link to comment Share on other sites More sharing options...
611 Posted May 11, 2013 Share Posted May 11, 2013 Nice one retro power, looks good. Im running the wilwood pedal as well for mine so just needed a hole through the bulk head :-) nova-baz got mine from Summit racing in the US and the pedals as well. Andy Quote Link to comment Share on other sites More sharing options...
nova-baz Posted May 15, 2013 Author Share Posted May 15, 2013 cheers for the help looks great! now to have a play lol Quote Link to comment Share on other sites More sharing options...
