1.8 Non Starter
garymanc
been trying to start this today changed the starter motor and its stii dead as a dodo , all the earths looked ok and i added another one direct from the battery when trying to start it.
will this be ignition switch ?
  • 1 month later...
Do not bridge the battery live on the starter to the starter solenoid spade terminal that the wire normally goes on to test it, and also do not put a female spade terminal on a length of wire to aforementioned terminal and via a push switch or similar to battery to enable you to test / eliminate it being the wiring or starter. Also do not secure and bench test the solenoid of the removed starter to see if you removed a good one.
fixed it ages ago was the earths or the ignition barrel , cleaned them and it fired into life
maybe if you spent less time on models m8.........................lol!!
not sure what you mean mate
i will note this for future ref.......... THANKS
