Shug Posted July 22, 2013 Share Posted July 22, 2013 After the plate that screws to the manifold that the injector sits in. It's for a 2.2. Dunno if 2.0 is the same. Link to comment Share on other sites More sharing options...
spiney_norman Posted July 22, 2013 Share Posted July 22, 2013 If anyone can confirm the 2.0 ones are the same I've got some you can have for nothing mate! Link to comment Share on other sites More sharing options...
paulmanta Posted July 22, 2013 Share Posted July 22, 2013 If you have a rubber hose type fuel rail then the base plates are the same, it only gets complicated when you start using 2.4 alloy rails, they have different injector holes. Link to comment Share on other sites More sharing options...
Shug Posted July 22, 2013 Author Share Posted July 22, 2013 Its a metal rail. I think I over tightened the retaining screw for the injector bracket and buggered the thread in the baseplate. Can hear air being drawn in when engine is running so guessing its the baseplate as injectors arent tightly held down like they are on the other side. Dunno if I can repair the thread somehow. Link to comment Share on other sites More sharing options...
paulmanta Posted July 23, 2013 Share Posted July 23, 2013 In that case you need a 2.4 injector base plate with new seals.....possibly available new but I might have one here, might as well do all 4 seals and both flat gaskets. Link to comment Share on other sites More sharing options...
