Clint Kember Posted September 6, 2013 Share Posted September 6, 2013 hi got a manta I need clutch 18 box onto a 2 litre red top garage has had it a week say they cant get a clutch say its obsolete or specialist only how does every body else get on when changing clutch help needed please cheers clint Quote Link to comment Share on other sites More sharing options...
dynamytedan Posted September 6, 2013 Share Posted September 6, 2013 calibra turbo clutch kit , with a pot type flywheel . use manta 1800 bearing . Quote Link to comment Share on other sites More sharing options...
Kevin Abbott Posted September 7, 2013 Share Posted September 7, 2013 I can do you a full kit but I NEED the old unit from the xe in exchange. If you can't get me an old xe pressure plate and friction plate then my supplier will not supply me a kit anymore. I've done kits for people and never had the exchange items so my supplier pulled the plug on all of them. Cheers Kev Retro Power can also do you a kit and I think they operate on a zero exchange. My kit is £100 but you need to send me the old unit before I can supply. Quote Link to comment Share on other sites More sharing options...
Clint Kember Posted September 7, 2013 Author Share Posted September 7, 2013 I can do you a full kit but I NEED the old unit from the xe in exchange. If you can't get me an old xe pressure plate and friction plate then my supplier will not supply me a kit anymore. I've done kits for people and never had the exchange items so my supplier pulled the plug on all of them. Cheers Kev Retro Power can also do you a kit and I think they operate on a zero exchange ok thank you the garage reckon they are getting the right clutch Monday if im stuck I will message you thank you very much My kit is £100 but you need to send me the old unit before I can supply. Quote Link to comment Share on other sites More sharing options...
Clint Kember Posted September 7, 2013 Author Share Posted September 7, 2013 calibra turbo clutch kit , with a pot type flywheel . use manta 1800 bearing . thank you Quote Link to comment Share on other sites More sharing options...
