240Clutch Disk From 2.6/3.0 Cih
Lesis
Hello.
There is problem to buy 240mm clutch disk from 2.6 and 3.0 Cih.I'm even considering finding used disk and replace the friction material.
Does anyone have used/new disk for these engines?I have balanced 2.4crank with lightened 3.0Cih flywheel and 240mm clutch plate.Only missing the disk.It would be pity to change whole clutch assembly.
I'm from Latvia,but shipping should be no problem.
First -2.4l crank,then together without flywheel,then all together with clucth plate.Without 60-2 C24Ne,but it still be used without balancing.I had access to balancing machine that conects to crankshaft through dampeners place(You can't put dampener and connect crank to balancing machine)
I assumed dampener as factory balanced.
