tocca Posted November 11, 2013 Share Posted November 11, 2013 Hi guys, going to be probably going down this method when it comes to fitting the C20XE motor. Does anyone know what I have to do? I Quote Link to comment Share on other sites More sharing options...
daverwd Posted November 11, 2013 Share Posted November 11, 2013 You will need a distributor & cam pulley wheel from an manta GT/J (1800cc engine) You will also need a mounting bracket ... this was supplied to me by one of the guys on here Gary Watson.. got a set of ignition leads made by Magnacor.. to take the old fitting on the distributor & the new type fitting at the plugs... hope this helps.. Quote Link to comment Share on other sites More sharing options...
daverwd Posted November 11, 2013 Share Posted November 11, 2013 Quote Link to comment Share on other sites More sharing options...
lepo5 Posted November 11, 2013 Share Posted November 11, 2013 PM kev abbot for one of the front mounted dizzy brackets. Quote Link to comment Share on other sites More sharing options...
tocca Posted November 11, 2013 Author Share Posted November 11, 2013 My manta is 1800 so I should have all the bits? 1 Quote Link to comment Share on other sites More sharing options...
tocca Posted November 11, 2013 Author Share Posted November 11, 2013 My manta is 1800 so I should have all the bits? Quote Link to comment Share on other sites More sharing options...
lepo5 Posted November 11, 2013 Share Posted November 11, 2013 You will have the bits, but you will need one of these. Quote Link to comment Share on other sites More sharing options...
tocca Posted November 12, 2013 Author Share Posted November 12, 2013 Oo where can I get one of them Quote Link to comment Share on other sites More sharing options...
lepo5 Posted November 12, 2013 Share Posted November 12, 2013 PM kev abbot for one of the front mounted dizzy brackets. Quote Link to comment Share on other sites More sharing options...
iano Posted October 16, 2015 Share Posted October 16, 2015 Hi I know this is an old topic but are these brackets still available Quote Link to comment Share on other sites More sharing options...
rutts Posted October 17, 2015 Share Posted October 17, 2015 Limited supply now if still available. Pm kev abbott or bigcliff for latest info Quote Link to comment Share on other sites More sharing options...
johnboy Posted October 25, 2015 Share Posted October 25, 2015 (edited) Hi there, I've got one of these brackets and all the other necessary parts such as the twin pulley off the 1.8 the small drive belt, dizzy and the belt cover with the slot cut out if interested. Edited October 28, 2015 by johnboy Same set up as this Quote Link to comment Share on other sites More sharing options...
MantaAndy Posted November 12, 2017 Share Posted November 12, 2017 Hi, Any chance you still have the bits for that set up available? Or maybe there's somewhere I can source them? Quote Link to comment Share on other sites More sharing options...
