Retro Power Posted January 4, 2014 Share Posted January 4, 2014 Thought I'd post a set of pics from the most recent ascona 400 replica that we are working on: As it came, a spanish lhd car that the owner had taken with him to germany a few years ago, it was bought on ebay.de and we brought it back to the uk a couple of days later, its stripped to a shell and ready to remove the underseal and then blast it following blasting and zinc primer: usual chassis rail rot time for some metal repair work!! Quote Link to comment Share on other sites More sharing options...
Retro Power Posted January 4, 2014 Author Share Posted January 4, 2014 Righto, we'll start with a little light sill mending..... now, to those that think its just a case of cutting off the crappy little bit at the back and whacking the new one on.........here's the job laid out in detail! ooh bit tired here, had the usual repair welded over, leaving all the strengtheners un-attached: cut out a bit further to access all the centre reinforcer cut out centre reinforcer make a new one inner bit not too clever either so make one of those too weld em in the old jacking point tube was knackered so make one looking much better now! Quote Link to comment Share on other sites More sharing options...
Retro Power Posted January 4, 2014 Author Share Posted January 4, 2014 next we'll have a crack at some a-post repair work not an unusual sight to the manta owner cut off the worst of the bodgery to see what we're looking at all trimmed away back to the inner, which isn't bad at all (seen them missing completely!!) some zinc primer then its time to make a new outer piece....here I have to say Stu (our main metal man) shows his mettle if you'll pardon the pun all welded in Quote Link to comment Share on other sites More sharing options...
Autocrosser Posted January 4, 2014 Share Posted January 4, 2014 Wow and double wow! Whatever your paying Stu it's not enough! Quote Link to comment Share on other sites More sharing options...
Retro Power Posted January 4, 2014 Author Share Posted January 4, 2014 a-panel before and after 1 Quote Link to comment Share on other sites More sharing options...
Retro Power Posted January 4, 2014 Author Share Posted January 4, 2014 time for the really fun bit, the chassis rails! new bit looks a bit better than old and new outer made up and fitted as usual, Stu goes one better than my usual efforts, and actually makes the inner rail with the same stepped joint that it originally had!!!! Quote Link to comment Share on other sites More sharing options...
Retro Power Posted January 4, 2014 Author Share Posted January 4, 2014 alignment check making up new outers all done 2 Quote Link to comment Share on other sites More sharing options...
*energy* Posted January 4, 2014 Share Posted January 4, 2014 Love your threads!metal work is out of this world Quote Link to comment Share on other sites More sharing options...
john p Posted January 4, 2014 Share Posted January 4, 2014 just goes to show how far the tinworm can go great job keep up the good work Quote Link to comment Share on other sites More sharing options...
Retro Power Posted January 4, 2014 Author Share Posted January 4, 2014 just goes to show how far the tinworm can go great job keep up the good work yep, and bear in mind this had a current TUV in germany, which is MUCH stricter than a UK mot, and it is really pretty good, one of the best manta/ascona b's we've worked on!!! Quote Link to comment Share on other sites More sharing options...
SCP Posted January 11, 2014 Share Posted January 11, 2014 (edited) looking much better now! Looks like the repair work is going well great metal fabrication That's a nice neat repair very solid should last many years Edited January 12, 2014 by SCP Quote Link to comment Share on other sites More sharing options...
