Spluttering At High Revs In 1St, But Drives Perfect?
devilwoo
Hi Guys,
The 2.0 has developed a splutter at high revs, noticeable when booting it in 1st, it soon evens out again. When driving normally it runs lovely. I have noticed when it is idling now and again it will be ever so slightly lumpy.
Any suggestions? It's going in for a rolling road tune-up and service next week and have the timing inspected etc… It's being done @ Injectors in Stockport so hopefully they should know what they're doing :D
id have a look in the distributor cap first and then look for any air leaks around the inlet area, maybe a partially blocked exhaust ?
an exhaust gas test might tell you something also.
the rolling road should find it , although its expensive fault diagnosis on that ill bet .
I reckon have a good look your self as much as you can , but its going to be difficult if the lumpy idle is intermittent .
If you can get the problem happening you'll have half a chance to try a few things ,like pulling off the servo pipe and blocking the hole to see if it improves .
good luck
you know where the brake master cylinder is , that's bolted to a large black round thing ...that's the servo ... there should be a meshy looking pipe coming from that and going to the inlet manifold .
although the pipe can look ok , it can start leaking/sucking in extra air through the material mesh stuff . to eliminate it , disconnect it at the manifold end and block off the take off on the manifold .If you then get a better idle it tells you its that .
don't drive the car with that disconnected , you wont have good brakes . just run the engine .
