Snowy Posted October 9, 2014 Share Posted October 9, 2014 Am I right in thinking the outlet on the inlet manifold would normally go to the header tank? If so can I blank it off and not use it? Also shouldn't the outlet at the back of the head go to the top of the heater matrix? Or is it ok as it is in the picture below? Thanks Quote Link to comment Share on other sites More sharing options...
rutts Posted October 10, 2014 Share Posted October 10, 2014 I had my heater hoses same way with no ill effects. small breather hose went to a 8mm pipe soldered into top of rad just to help bleed up and keep it all flowing. Quote Link to comment Share on other sites More sharing options...
Snowy Posted October 10, 2014 Author Share Posted October 10, 2014 I had my heater hoses same way with no ill effects.small breather hose went to a 8mm pipe soldered into top of rad just to help bleed up and keep it all flowing. Cheers. I've just moded the rad to add to accept that pipe Quote Link to comment Share on other sites More sharing options...
