Power Flex Suspension Bushes
wayne ingham
Hi to all , This is a question about power fix suspension bushes all opinions are well come,for/against ,is the money,time,grief worth it.Will the suspension be to hard , is the different grades of bushes.Has any one fitted this type off bushes .Ihave heard that the ride will be to hard.At £400.00 I have to have all the info I can get.Cheers Wayne
I've fitted poly bushes to different vehicles over the years and to be honest the only difference I've noticed is that the steering/handling feels more precise. Last car I've done I've replaced ponly bushes with nylon and all I've noticed is the suspension feels more taught!! Rubber bushes are a compromise, I'd go with poly ones every time.
Fit them! Totally transform the car, only worth fitting them though if you 'drive it' and not tootle about in it and also only worth fitting them if your car has an uprated suspension otherwise it's kind of pointless. As for ride you can go as hard as you like as I think there's three different compounds of bush. Hope this helps but I am saying fit them (full set) otherwise car can feel unbalanced, it tightens the car up.
