Gte Will Not Idle When Cold
Chris M
Hi
My GTE will not idle when cold. Having had a mooch round on the internet I have discovered that the brown temp sensor is the Thermo time switch which tells the ECU to spray fuel into the plenum via the cold start injector at the back.
I have tested this by removing the cold start injector, pointing it into a clear water bootle and then cranked the engine. Sure enough it sprayed a small quantity of fuel.
This leaves me to suspect the blue temp sensor may be at fault. Once warmed up it drives a treat, pulls like a train and ticks over fine albeit a bit lumpy due to the Kent cam.
Am I right to suspect the blue sensor or can there be anything else.
If it proves to be too techy I am prepared to live with it as it soon warms up it would just be nice to have it tick over when cold and I have found genuine Bosch blue temp sensors for less than 20 quid on Flea bay.
Cheers
Would that effect it not ticking over when cold?
Everything was rebuilt a year or so ago when the head was taken off and a new cam fitted .
Thanks for the response though. Auxiliary air valve checked the other day. Very slightly open when cold and closed when warm
Edited by Chris M
No worries dude. Sometimes the reason for "the test" takes longer to explain than to do so I don't explain. However, I don't have a vested interest in knowing the answer because my Manta runs fine with an engine I have had for 22 years.
The inlet manifold is thinner than the exhaust manifold and held by the same bolts, they come loose all the time, especially when just refitted and the subsequent air leak causes them to idle lumpy and stall at idle speed. As can a lot of other things, but people always start messing with the injection before doing the basics, which means they then have more problems not less. For example people love to play with the AFM screw to try and solve idle problems and ruin their AFM when they should not have touched it.
