How To Remove Door Strap Mounts From A Post Manta B
CRAZYDAVE
As above how do these come out? I've removed the doors and have the small mount that goes through a slot in the A post for the strap pin to go through to remove but it doesnt want to budge. I always thought that they were held in by a slide on retaining clip on the inside is this correct?
Edited by CRAZYDAVE
If its the little domed rivet the attaches the check strap to the body then i use a sharp chisel on the bottom and then you can knock the rest upward and out
Cheers
Andy
Hi Andy
I have the door removed completely and the pin removed. It is the bracket on the a post that has the hole for the pin that i would like to remove.
Cheers
Dave
