tom child Posted February 20, 2015 Share Posted February 20, 2015 Can anyone help got car out tonight first time in 18 months started first time but won't run got a knocking noise from air flow meter when I push accelerator down and cuts out Cheers Tom Quote Link to comment Share on other sites More sharing options...
wayne ingham Posted February 20, 2015 Share Posted February 20, 2015 Have you checked the air filter no thing living in ther ,If you find it is a air flow meter I have a good one (tested on my Manta 2.0E) if this helps you out Wayne Quote Link to comment Share on other sites More sharing options...
mantadoc Posted February 20, 2015 Share Posted February 20, 2015 First step 2 P trick http://forums.mantaclub.org/topic/12777-injection-relay-limp-home/ Second step, check for spark (most times if when the ignition is turned on so ignition lights on (not cranking) if the rev counter needle twitches once you have a spark (or at least correctly powered coil amp) Third step, Manta will start and idle with AFM wires disconnected (only idle will stall as soon as throttle touched) The fuel pump runs through fuse 7 on a GTE, and those of you who have tried will know you can pull every fuse out of the box but 7 and a Manta will still run. So what's the point? Well if your injection relay goes you can usually limp home like this, a copper coin bridges either fuse 6 or 8 to 7 to power the fuel pump. Leave the injection relay in place when doing this or the injection won't run. Other uses: Ran out of fuel and don't want to flatten the battery cranking while you wait for pressure Emptying the tank / flushing new pipes Finding out which is the feed if you don't trust going by pipe position Some muppet connected an imobilizer / cut out switch badly Fuel pump live will back feed to ignition, so you can pull the key out and leave the car running Downsides, if its a poor connection the coin can get hot so don't melt the fuse box No warranty implied or given..... Quote Link to comment Share on other sites More sharing options...
wayne ingham Posted February 25, 2015 Share Posted February 25, 2015 Hi Tony have you checked that the air flow back up flap has movement (that's the bit inside the air flow meater ) fuel injection relay,inside distributor cap . it is a 2.0 lit engine ? Check air pipes to pressure reg ect.Have you put fresh petrol to the fuel system Cheers Wayne Quote Link to comment Share on other sites More sharing options...
wayne ingham Posted March 4, 2015 Share Posted March 4, 2015 Hi tony can't get on my e,mail thing .Have not got a box ,padding .Will have to get box ect from work (off this week)Hop that's ok ,will check on this site for a replay .Cheers Wayne Quote Link to comment Share on other sites More sharing options...
mantadoc Posted March 5, 2015 Share Posted March 5, 2015 (AFM knocking on cranking is normal. Slow turning engine sucks air intermittently) Quote Link to comment Share on other sites More sharing options...
