Aggressor Posted July 21, 2015 Share Posted July 21, 2015 Just wondering is it alot of hassle to shorten the gear ratios in a 1800 gearbox if it can even be done at all... Quote Link to comment Share on other sites More sharing options...
rutts Posted July 21, 2015 Share Posted July 21, 2015 Probably cost a good few pounds if you could find the gears to do so. Dogleg 265 with direct top gear would be good but expensive. Or take a look at the mazda rx8 conversion 6 speed close ratio can be fitted to a red top engine. Uses ford clutch plate ford prop similar size to a type 9 ford box. Quote Link to comment Share on other sites More sharing options...
MANTAMAN Posted July 21, 2015 Share Posted July 21, 2015 Caterhams have used Mazda gearboxes, so they can't be too bad, it would be the physical diamentions that could be a sticking point, i think they have a long tailshaft putting the lever a long way back. Quote Link to comment Share on other sites More sharing options...
rutts Posted July 22, 2015 Share Posted July 22, 2015 Same as a type 9 where gearstick comes into cabin around handbrake front area so not too bad. Quote Link to comment Share on other sites More sharing options...
Aggressor Posted July 22, 2015 Author Share Posted July 22, 2015 ok cheers lads Quote Link to comment Share on other sites More sharing options...
