'87 2.0 GTE Oil pressure sender/switch
Manta Mender
As title says really.
Need sender/switch units for an '87 2.0 GTE coupe. Would like prices for either new or used.
If anyone can provide pictures I'd appreciate it. Located RG10.
http://www.ebay.co.uk/itm/OPEL-MANTA-A-B-70-88-OPEL-MONZA-78-86-OIL-PRESSURE-SWITCH-50930-/131419468808?hash=item1e9935f408:thumbup
Thanks! That's the switch sorted for the warning light, now do you know where I might find a sender that would suit the Manta's gauge? ^_^
do you mean a voltage stabilizer/semiconductor,if so there's this, which will be better than what was originally fitted aswell.
http://www.ebay.co.uk/itm/Semiconductor-Voltage-Stabilizer-Vauxhall-Opel-Manta-/281822167877?
Basically I'm after a pressure sender with variable resistance curve to feed the gauge. I believe what you linked is a switch just for the warning light? (Unless I'm wrong, which is quite often the case:P)
I have seen those voltage stabilizers but the one in the back of the dash works fine for now.
THAT looks more like it David! So would that operate both the warning light and gauge? May I ask where one can acquire such a device? Cheers!
That is not the sensor for a Manta B, the original one has 2 threaded terminals with adaptors on to turn to spade fittings and looks like this
http://www.ebay.co.uk/itm/Oil-Pressure-Sender-Sensor-Vauxhall-Astra-Cavalier-Senator-Cavalier-Cc-53850-/371332990978?fits=Model%3AManta+B&hash=item56752bc802 Would this be what I'm looking for?
oh bugger I bought the oil pressure switch  that goes into the block,which i was informed was the reason my gauge was not working,(not fitted yet )
but it looks like i may need the above aswell:blink:
