davo Posted January 25, 2016 Share Posted January 25, 2016 (edited) As per the title. I know I need all the right bits to get the xe engine set for rwd. Does it fit straight in onto manta A crossmember ? Are there any under bonnet alterations to make ? Will an 1800 box fit the tunnel? Or any other info I may need. Oh& pictures would be great too !!! Cheers Edited January 25, 2016 by davo Quote Link to comment Share on other sites More sharing options...
upk Posted January 25, 2016 Share Posted January 25, 2016 It fits ok & with 1800 box Quote Link to comment Share on other sites More sharing options...
davo Posted January 26, 2016 Author Share Posted January 26, 2016 Cheers Kev. So that's it drops in no alterations req? Quote Link to comment Share on other sites More sharing options...
upk Posted January 26, 2016 Share Posted January 26, 2016 You may need to put spacers under engine mounts to clear crossmember with sump. 1800 sump and pick up pipe is needed. As is 1800 engine mounts. exhaust down pipe will need modification to clear anti roll bar. you will need to make a new gearbox mount. front brakes will need upgrading! depending on fuelling option you may need to reposition servo or use a remote unit. its fairly straight forward but only if you have the skills to take it on!! Oh and you need to sort your fuel tank with a return line if using injection fuel system. What are you thinking for ignition, dizzy at front or plug and play Ecu option? Quote Link to comment Share on other sites More sharing options...
davo Posted January 26, 2016 Author Share Posted January 26, 2016 Pretty straight forward then. I'm going bike carbs & nodiz for ignition. Defo will upgrade brakes !! Tweeking exhaust & gearbox mount should b able to cope with that !! Cheers Quote Link to comment Share on other sites More sharing options...
611 Posted January 26, 2016 Share Posted January 26, 2016 Webcon do a nice swirl pop for injection http://www.webcon.co.uk/shopdisplayproducts.asp?id=48&cat=EFI+Pressure got the intank one running in mine and its nice and easy to hook up. Andy Quote Link to comment Share on other sites More sharing options...
