NickSed Posted May 13, 2016 Share Posted May 13, 2016 (edited) Hi guys, I'm looking for a 2.2 head to recon for my GTE. Ive looked around and a ported 2.0 seems to be on par with a 2.2 so would prefer to start there. I'm based near Warwick. Any info would be appreciated. Thanks Nick Edited May 13, 2016 by NickSed Link to comment Share on other sites More sharing options...
moodoo Posted May 14, 2016 Share Posted May 14, 2016 (edited) Hi Nick, You do know that the 2.2 manifold isn't a straight fit under the bonnet, as it sits too tall because of the 2.2 heads raised inlet ports? I built a 2.2 engine, but I used a ported 2.0 head, I was able to keep the standard 2.0 manifold without having to trick about with getting it to fit the 2.2 head. Maybe you know all this already, but better to check I thought... Cheers, Fin Edited May 14, 2016 by moodoo Spelling 1 Link to comment Share on other sites More sharing options...
paulmanta Posted May 15, 2016 Share Posted May 15, 2016 2.2 injection inlet manifold will bolt on to the 2.2 head and fits in the manta engine bay with no problems. I have done loads of 2.2 / 2.4 conversions and all have had no bonnet problems. The inlet you want to use however is a cut down 3 litre Monza one, cut the back two ports off and weld it up and it will flow better and have a nicer inlet butterfly. Link to comment Share on other sites More sharing options...
