Crossmember solid top mount conversion plates
mantasrme
I had to design a set of these for a project along with lower wishbone strengthening plates so while i was at it i got some spares cut. These are laser cut plates from 2mm steel to convert the manta front crossmember top mount to a solid mount. Combined with poly or solid mounts in the outriggers this will give a more positive feel to the handling.
Start with an original top mount,
Trim the rubber back flush with the sides (I used a 1mm slitting disc)
Drop the plate onto the end
Then weld around outside and the middle tube, sand down the weld, then flip over and do the 2nd side.
These are £10 a set of 4 and can post for £2 (will combine postage with strengthening plates) or collection from Harrogate North Yorkshire
