IanMc Posted November 11, 2017 Share Posted November 11, 2017 For my resto I will need to remove both my front and rear screens - two questions: - what is the best technique for removing them? - are the screen rubbers readily available and from where? Thanks as always. Quote Link to comment Share on other sites More sharing options...
andyc Posted November 11, 2017 Share Posted November 11, 2017 First of all try and find new or good set of seals, if you can then you cut your seals and lift the screens out. If not remove the filler strip in the seals, either chrome or black and then its a case of work the seal from the inside a small piece at a time and pray the gods are on your side. Or call in an independent windscreen company as they will have all the proper tools Andy Quote Link to comment Share on other sites More sharing options...
IanMc Posted November 11, 2017 Author Share Posted November 11, 2017 Thanks again Andy, much appreciated. Can anyone suggest a good place to source the original seals, or is good old eBay again? Quote Link to comment Share on other sites More sharing options...
mantaray Posted November 11, 2017 Share Posted November 11, 2017 If it an A series then East kent trim to both front and rear seals Quote Link to comment Share on other sites More sharing options...
IanMc Posted November 12, 2017 Author Share Posted November 12, 2017 No sorry, it’s a Cav Coupe. Apologies, I should have said. Quote Link to comment Share on other sites More sharing options...
