IanMc Posted May 27, 2019 Author Share Posted May 27, 2019 2 hours ago, cam.in.head said: Hi Ian.what was the actual issue then? . Did you find why there was a blockage ? . Or do you think you had tightened up the clips so tight that they actually closed up the stubs ? .? I think in the end there was two issues Chris. When it was running before, I used to really struggle to keep it going. I had convinced myself that this was caused by the carb being out of tune. But now I think that this was fuel starvation caused by the restrictions on the pump stubs. This was compounded by a blockage in the fuel line, caused by who knows what. That will be investigated further on another day... Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted May 28, 2019 Share Posted May 28, 2019 Or the aftermarket pump being no good. .? The originals are designed to be correct stroke when having the heat proof spacer block fitted. Not sure about some aftermarket. Quote Link to comment Share on other sites More sharing options...
