Jason b Posted June 8, 2019 Share Posted June 8, 2019 Bit of an odd query this... I'm fitting a very tight fitting rollcage and wanted to check that in the event I may not have be able to quite get the rope method to work all the way round, has anyone fitted a manta B coupe screen from the outside using a plastic trim tool or or similar to flip the lip over the screen? I'd do a test but currently don't have a windscreen as the car was bought as bare shell and I'm intending on fitting a heated one when I get that far. Thanks for your thoughts, Jason Quote Link to comment Share on other sites More sharing options...
IanMc Posted June 8, 2019 Share Posted June 8, 2019 You will have to work inside at some stage as the ‘inner lip’ of the screen seal has to be pulled to the inside of the car. I used some roller blind cord (1-2 mm dia. from memory), so you would need to have a very tight cage to not be use that method. Good luck! Quote Link to comment Share on other sites More sharing options...
