Brake equaliser
Dave1958
Hi
Now managed to rebuild the brake system on my 79 2.0s
However I noticed that there is some sort of valve or fitting tapped into the body of the equalisation valve on the bulkhead side .Its a bit like a recessed hex fitting with what resembled a valve stem partially sticking out .
i wiped out all the grime to notice a rubber seal that had disintegrated .
Please  tell me this is not a moving part that now needs a rebuild or alternatively will lead to brake failure .
I have left the brake pressed on for a while and the calipers and drums lock off ok and release when you depress the pedal . None of the new unions leak so all is good .
However is there going to be a problem with the brake equaliser and this rubber seal .
Is it a moving part and do I need a new seal that probably isn’t available ?
Anybody know the answer ?
Thanks
