New Manta and Ascona B series parts
CalCol
All of these are new genuine parts.
Rear 1/4 window weatherstrip in black, left or right - 09282817 (1 52 004) - £65
Suits both Manta and 2-door Ascona
Door top weatherstrip, Manta, right - 09282840 (1 52 255) - £85
Rear quarter window, Manta coupe, green glass, black hinges, left - 90287887 (1 63 698) - £100
Rear quarter window, Manta coupe, green glass, black hinges, right - 90287888 (1 63 699) - £100
B-pillar moulding, Manta coupe, right side - 09283782 (1 83 895) - £90     1 sold!
Body side moulding, front door, 4-door Ascona, left - 09288817 (1 72 503) - £35
Body side moulding, rear door, 4-door Ascona, right - 09288820 (1 72 506) - £25
Body side moulding, door, Manta, right - 90089840 (1 72 542) - £35
I also have the following new body side mouldings (all same style as above) but no pictures:
Manta, side panel, rear, right - 09286524 (1 73 030) - £35
Manta side panel, front, left - 09288825 (1 72 507) - £35
Ascona 4-door, front door, left - 09282757 (1 72 716) - £25
Manta hatch, side panel, rear, right - 09285226 (1 72 926) - £30
Ascona 2-door, side panel, front, right - 09288814 (1 72 510) - £30
Ascona, side panel, rear, left - 09282767 (1 73 031) - £30
Manta side panel, front, right - 09288826 (1 72 508) - £35
Ascona, side panel, rear, right - 09288816 (1 72 514) - £30
Rear bumper rubber trim, Ascona, centre - 09282140 (14 09 020) - £30
Happy to post any of these at your cost or you're welcome to pick them up from Reading.
Thanks,
Nick
  • 3 weeks later...
Not had any carb parts for years, I'm afraid Julian.
New manifolds are very rare, especially as they're handed (RHD manifolds are different to LHD ones) so the usual German suppliers won't be able to help either. Best I can suggest is finding a good used (un-cracked) one, shot blast and fix any broken screw remnants you might have, then get it ceramic coated to preserve it. Paul Newport may be able to help with a used core - he has a seemingly endless supply of used parts...
Nick
  • 4 weeks later...
Hi Luis,
No, sorry. This is the strip that goes up the A pillar and across the top of the door opening to seal the glass against the body. The one that seals against the B pillar is the other half of the door seal and seals the lower half of the A post, the bottom of the door opening and the B pillar.
The seal you're after is coloured to match the upholstery, which colour are you looking for? And which side? If you're in Spain then your driver's side is left, in England it's right... :)
Thanks,
Nick
7 hours ago, CalCol said:
Hi Luis,
Thanks,
Nick
Hi Nick
Are you saying the full  door seal is composed of two parts And the One I need is the one which seals the half bottom of Pilar a, the bottom of the door opening ( across the sill) and b pillar. Is the B pillar in full all the way up to the top "corner"?
I'm not any near to the car at the moment, but I guess the interior trim is grey.
And the side I need is the right hand side. Driver side in the UK, passenger side in Spain
Correct. If you need the piece that seals against the B-pillar you need the lower half. Also, be careful as the lower seal is different between coupé and hatchback (CC).
For the grey interior (trim 159, 359 or 599) the part numbers are:
1 57 097   /   90238330     Hatchback, right side
1 57 098   /   90236338     Coupé, right side
The other "grey" is called anthracite, it's a darker grey. The trim codes for anthracite are 158, 188, 358, 458 or 598 and the part numbers are:
1 57 013   /   90171107     Hatchback, right side   (I have two new ones of these in stock)
1 57 005   /   90171115     Coupé, right side
On later cars (with a square VIN plate in the engine bay) the trim code on the line marked "Farbe   Color"  and is the second number on that line.
Nick
