Temp sender not working and advice on how to test it.
611
The old temp sensor does not seem to be working as i have no reading on the gauge. Is there a way to test it before i remove the sender, just in case its not that?
Thanks,
Andy
pull the connector off the sender and give it an earth gauge should sweep over to max
I suppose you could also put a resistance meter on the sender when cold value should decrease as warms up will tell you if the sender is dead or you have a wiring issue or gauge.
Edited by hoobby
Thanks for the info, a little job for the bank holiday 🙂
