Kurtupsin75 Posted April 12, 2021 Share Posted April 12, 2021 Hi all I'm after pair brake hoses for my cavalier I got some from Germany but the connectors are to small 15mm spanner size, got a pair correct ones off ebay old stock right connectors 17mm but hoses are corroded. Any leads or specialist be great also the length if possible in mm ones I got 420mm in full length thanks keith Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted April 12, 2021 Share Posted April 12, 2021 mine are 411 mm tip to tip so your 420 sounds near. i would again suggest ebay. always buy all my stuff from there. if the hoses are faulty the seller or ebay should sort you out anyway. and maybee buy from another seller. plenty of choice 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted April 12, 2021 Share Posted April 12, 2021 and as far as i can remember its bh247 for early models without location slot and bh248 for 76 onwards . just checked now ,there are a few on . 1 Quote Link to comment Share on other sites More sharing options...
Kurtupsin75 Posted April 19, 2021 Author Share Posted April 19, 2021 Just double check tip to tip length is 415mm got some from Germany silver end to small gold ones are correct in size got some braided hoses made to the correct length on full lock touches tyre. 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted April 19, 2021 Share Posted April 19, 2021 hi.just re measured mine. yes 411 mm but are standard hoses not braided. mine fit fine and clear 185/70/13 tyres fine .maybee your braided ones are touching due to the end ferrule.it looks longer than a standard hose ? never used braided so cannot comment on them. still some normal ones on ebay or maybee tweak the bracket a little ..? 1 Quote Link to comment Share on other sites More sharing options...
