Metalbasher Posted September 21, 2022 Share Posted September 21, 2022 Hello all. I’m looking at the original fuel line components (tank to pump) on my 1980 Sportshatch. There are three metal pipes that are part of the fuel line, the longer two of which I’ve forgotten where they are located (having took them off the car some 30 years ago). Haynes offers no insight, can anyone help remind me how the two are positioned? Photos maybe? 1 Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted September 22, 2022 Share Posted September 22, 2022 Think it’s supposed to be 1 piece from tank to front, rubber to lift pump, then a pipe that goes back around rear bulkhead ? To feed carb Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted September 22, 2022 Share Posted September 22, 2022 (edited) the longer metal peice just goes from the tank outlet(via a short hose) around the front of the tank above the rear axle. yellow pvc / nylon to front and stops near alternator. hose down to fuel pump . short hose to metal pipe up front of engine by top radiator hose and to carb inlet.(via hose on 1.6) small metal bracket to camshaft cover bolt. Edited September 22, 2022 by cam.in.head 1 Quote Link to comment Share on other sites More sharing options...
Metalbasher Posted September 22, 2022 Author Share Posted September 22, 2022 Thanks both. Did make me think that I may have the cut pipe into two when fitting a Malpassi fuel filter, but if one length is installed near the tank that makes sense. I’ll take a look at the fit-up the weekend 1 Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted September 23, 2022 Share Posted September 23, 2022 yes on the carb models the yellow fuel line runs down the passenger side but the tank outlet at theback is on the drivers side hence the metal link pipe above the axle. 1 Quote Link to comment Share on other sites More sharing options...
Metalbasher Posted October 14, 2022 Author Share Posted October 14, 2022 Can anyone tell me how this fuel line bracket is bolted to on the engine please? My bracket is broken so will need to repair, but I can’t recall to what it is attached to to help construct the fixing (stock photo by the way, not my car).. Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted October 15, 2022 Share Posted October 15, 2022 it screws to one of the front cam cover bolts(the triangular plate) shouldnt be difficult to make a little bracket. the original also has a little extra section that the vacuum advance pipe can hook into as well but most are cable tied to the top hose . Quote Link to comment Share on other sites More sharing options...
Metalbasher Posted October 16, 2022 Author Share Posted October 16, 2022 Thanks. I’m assuming it fits to the front of the plate, rather than the sealing face to the cylinder head? My bracket is intact other than needing the mounting hole section adding again, looks like it fractured at some point. Quote Link to comment Share on other sites More sharing options...
