1.8 5speed box to c20xe
Greg w
Specialist like https://clutch-specialists.co.uk in Leeds will definitely be able to help you. You have a couple of options, but any FWD car that used the F28 gearbox is the correct driven plate. See thread above as it also has a contact for another specialist that might be an option for you.
You should be using the flat XE flywheel btw
