®evo03 Posted February 8, 2023 Share Posted February 8, 2023 Had a fuel sender fail before, it wouldn't lift the needle, and swapped it out. There is a test for them, Haynes Manual. On the temp side, I'm usually half way under normal driving conditions. That be average 18°C, moving steady. Normally doesn't rise above half way, infact never, seen it. I take it it a carb model A. Temp sensor? You said you flushed Rad, how about heater matrix? 1 Quote Link to comment Share on other sites More sharing options...
