c20xe
Greg w
If you use a measured amount of oil, then grind the mark on any stick, that will give you a low and high readings.
let’s say ideal is 4L, then low mark would probably be after adding 3.5L .
Add another 0.5L and wait to drain down, then that gives the normal mark.
If you want high, then just decide the distance between low&normal and mark that.
