Kr1s Posted May 17 Share Posted May 17 (edited) Hi all I'm pleased to report that my (was my Dad's) Manta, a 1980, 2.0 SR Berlinetta finally arrived at my home today. It's taxed and insured, so I risked a run down to the shops and back - a whopping half mile or so in total! It's due in the garage for a full check over the week after next, but what I've noticed is that it's quite difficult to find gears, with large movement of the lever being required. Is this normal and if not, any clues as to the cause? As always, thanks in advance. On a different subject, anyone from here going to be at the Basingstoke transport festival on Sunday? Cheers! Chris Edited May 17 by Kr1s added model info Quote Link to comment Share on other sites More sharing options...
Jessopia74 Posted May 17 Share Posted May 17 Well grats on getting it back. Guess it could be wear, the 4speed has a few links, so small wear in each one would give that feeling 2 Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 17 Share Posted May 17 The 4 speed typically has a longer throw than the 5 speed. As Jessopia says, it has some long rods down the side of the gearbox and they go into the side of the box. Get someone to select the gears while you’re underneath and see if any of the joints are loose/have play. Also are you struggling to get gears while engine is running, off, or both? 2 Quote Link to comment Share on other sites More sharing options...
Kr1s Posted May 17 Author Share Posted May 17 Ooh, that's great news to learn that the linkages are outside the 'box! I can check that fairly easily. Didn't really have difficult engaging the gears - just finding them! Doesn't seem to be affected by whether it's running or not. Wear would be surprising as it's only done 28k or thereabouts - I'm wondering about any degraded plastic parts as it's been standing for most of the last 30 years though. Thanks again! Chris Quote Link to comment Share on other sites More sharing options...
Sutty2006 Posted May 17 Share Posted May 17 And something may be loose, always worth a look over 👍 1 Quote Link to comment Share on other sites More sharing options...
Kr1s Posted May 18 Author Share Posted May 18 Update: At least one of the linkages is very loose - it seems the pivots have nylon(?) bushes and they have disintegrated. Many thanks for the steer on the linkages! I suspect now I'm going to have to do some dismantling, work out the original dimensions of the bushes and get some made. If anyone has been through this and can share any hints/tips, they would be much appreciated! Oh, it also looks like there's an oil leak unless that's all dripping from the sump plug 😔 Cheers! Chris 1 Quote Link to comment Share on other sites More sharing options...
