Suzy Posted April 2, 2009 Share Posted April 2, 2009 Guy's I am now welding the manta back together, I need to treat the metal on the front wheel arch that holds the door before I repanel over the top. What would you recommend, thought about Jenolite, what do ypu recemmend. Thanks Suzy Quote Link to comment Share on other sites More sharing options...
vauxsenb Posted April 2, 2009 Share Posted April 2, 2009 For what its worth I painted mine firstly with Bilt Hamber's Hydrate 80 then a couple of good coats of red oxide (or zinc rich primer), a flash coat of body colour then a good couple of coats of you fav underseal. Hope that helps, Cheers, Colin. Quote Link to comment Share on other sites More sharing options...
Leon Posted April 5, 2009 Share Posted April 5, 2009 Clean with Bilt-Hamber DeOx Gel and paint with Bilt Hamber Hydrate80. Quote Link to comment Share on other sites More sharing options...
Atlantean Posted April 5, 2009 Share Posted April 5, 2009 ATEOTD it's hard to beat Bilt Hamber Quote Link to comment Share on other sites More sharing options...
gunman Posted April 5, 2009 Share Posted April 5, 2009 be careful with jenolite, if its not cleaned off properly is causes paint not to stick right. There is no substitute for removing rust. i dont mean chop it out but I used a wire cup brush and a grinder to remove. I used jenolite as well once it was removed just to make sure. Sand blasting is by far the best method, doesnt suit everyone tho. Quote Link to comment Share on other sites More sharing options...
sean999 Posted April 6, 2009 Share Posted April 6, 2009 Clean with Bilt-Hamber DeOx Gel and paint with Bilt Hamber Hydrate80. Quote Link to comment Share on other sites More sharing options...
sean999 Posted April 6, 2009 Share Posted April 6, 2009 Clean with Bilt-Hamber DeOx Gel and paint with Bilt Hamber Hydrate80. whats bilt hamber???? never heard of it, where sells it??? sean999 Clean with Bilt-Hamber DeOx Gel and paint with Bilt Hamber Hydrate80. Quote Link to comment Share on other sites More sharing options...
garymanc Posted April 6, 2009 Share Posted April 6, 2009 http://www.bilthamber.com/ Quote Link to comment Share on other sites More sharing options...
