Headlamp Wash/wipe System
baldbrian
where is the headlamp washer relay located? does this wash wipe system have a common fault?
I seem to remember seeing a device behind the drivers headlight but it maybe just a connection for the washer tubing.
Just to clarify, the washers only work when the headlights are on and you press the screenwash button.
i think the device you mean is like a small pump as there are electrical connectors on them,i think the relay is near the washer bottle
edit....... there a solenoid valve
