Redtop Oil Gauge Wiring
orm09
Hi,how do you connect the oil pressure gauge with a redtop in a manta? there is only one wire from the redtop loom but two on the manta.Also the temp gauge is'nt working but the fuel gauge and volt meter are.Could this be down to voltage regulator? Any help would be much appreciated.
put the oil sender unit from manta engine into red top and connect as usual. temp wire is solid blue coming from the manta loom that has coil and heater wires in it just put it on the red top sender on thermostat housing just under the ecu temp sender unit.
