big g13 Posted January 30, 2010 Share Posted January 30, 2010 Hi lads, I finally got round to servicing the carb on my ascona and its running much better. I still have a problem with it cutting out when I brake hard to a stop tho. Could it be something to do with the vacuum to the servo? everything seems to be plumbed in right including the oneway valve but I have to keep it alive when braking for junctions. Its a 1.9 with zenith Any idea? Cheers G Quote Link to comment Share on other sites More sharing options...
manta400john Posted January 30, 2010 Share Posted January 30, 2010 My old A ran like a bag O' shite at idle and it was drawing air through the servo pipe. The pipe was of the braided type and I think it was probably the original,replaced it and things were fine. If you replace it make sure you get the correct stuff, any good motor factor will stock the right stuff. Have you set the carb up by ear or have you had a CO tester up its bum? Quote Link to comment Share on other sites More sharing options...
big g13 Posted January 30, 2010 Author Share Posted January 30, 2010 Cheers John I'll get a new bit hose and give that a bash. Its not in the greatest nick right enough. I just screwed all the settings back to as they were before I striped it and it seems not bad. Could probably do with a decent setup. Quote Link to comment Share on other sites More sharing options...
mantadoc Posted January 30, 2010 Share Posted January 30, 2010 When you brake the servo lets air into the inlet manifold making the car run lean. If replacing the servo hose solves the problem it means you are runnign too lean already with air leaks and braking is the straw that breaks the camel's back. Otherwise you're a little lean at idle. Quote Link to comment Share on other sites More sharing options...
big g13 Posted January 31, 2010 Author Share Posted January 31, 2010 Tryed a new hose today and went for a blast. No change Mantadoc - Cheers that sounds about right. I will have a play with the mixture screw Quote Link to comment Share on other sites More sharing options...
