hoobby Posted March 12, 2010 Share Posted March 12, 2010 hi there just need to know the thickness for the inner and outer skin of the chassis leg and also the floor pans cheers Quote Link to comment Share on other sites More sharing options...
keith1200 Posted March 14, 2010 Share Posted March 14, 2010 Outer chassis leg; 1mm Inner swan neck; 1.5mm Inner low leg; 2mm Once you cut away the outer, you'll understand. Quote Link to comment Share on other sites More sharing options...
mantadoc Posted March 18, 2010 Share Posted March 18, 2010 Outer chassis leg; 1mm Inner swan neck; 1.5mm Inner low leg; 2mm Once you cut away the outer, you'll understand. I though outer chassis leg is about 1.3 Think both inners are thicker than that too but didn't measure Quote Link to comment Share on other sites More sharing options...
keith1200 Posted March 21, 2010 Share Posted March 21, 2010 (edited) Spent nearly £30 buying a measuring kit from Machinemart, to measure the chassis leg. http://www.machinemart.co.uk/shop/product/details/cm250-measuring-set After welding the new metal in? it looked good A post covers are only 0.8mm. Anyhow I could be wrong but it did work for me. ps also checked the left-hand lenght-wise member and that was 1mm. [edit] Eckhard's outer chassis leg replacements are 1.5mm sooo I'm probably right about the 1mm Edited March 21, 2010 by keith1200 Quote Link to comment Share on other sites More sharing options...
mantadoc Posted March 25, 2010 Share Posted March 25, 2010 Spent nearly £30 buying a measuring kit from Machinemart, to measure the chassis leg. http://www.machinemart.co.uk/shop/product/details/cm250-measuring-set After welding the new metal in? it looked good A post covers are only 0.8mm. Anyhow I could be wrong but it did work for me. ps also checked the left-hand lenght-wise member and that was 1mm. [edit] Eckhard's outer chassis leg replacements are 1.5mm sooo I'm probably right about the 1mm Still looks like 1.26 something to me Quote Link to comment Share on other sites More sharing options...
keith1200 Posted March 25, 2010 Share Posted March 25, 2010 (edited) [edit aboot the third/forth time] you know wot? It dosen't matter. 1mm worked from me Edited March 25, 2010 by keith1200 Quote Link to comment Share on other sites More sharing options...
