Project Rumble B
Sutty2006
I had originally gone up to my workshop for a tidy up yesterday...
Pushed the car out
Had a quick scan around
Then had a scan inside before pushing her back indoors
Then proceeded to tear the front axle off!
Apart from some minor holes to patch, mainly just cleaning up and finishing underneith!
Tips for bear metal restoration greatly taken. Was thinking Red oxide primer first, then paint, then.........? How does everyone else do it?
It needs to be bare metal, so id either go with a soft grinder og a blaster if you can afford it. I use Hammerite metal paint for my projects. I started with using some zink primer but that stuff is not worth the can it comes in ! So a big fat hammerite paint does the job for me, it stays liquid and wont chip off if you hit it or scrape it. Finish with a good tectrol seal or similar.
for the body work, use fibre strip discs. If you use them carefully you can make them go a decent way.
Underneath, underseal can come off with thinners, maybe nitromors. If its dried out a paint scraper might take chunks of it off.
For the rest, use your wire wheel.
