mantapaperman Posted January 18, 2011 Share Posted January 18, 2011 hi all. got doors back from paint and built them up. but cant seem to get gap right at top when shut? i either get glass hitting rubber to much at door handle side or a slight gap at front edge at top? i've now settled for a perfect fit everywere but at the front top edge area there is a 2mm gap when wound right up..anyone had fun and games with these before? cheers Quote Link to comment Share on other sites More sharing options...
garymanc Posted January 18, 2011 Share Posted January 18, 2011 have your door corner rubbbers fell to bits http://www.afterbuy.de/afterbuy/shop/storefront/start.aspx?shopid=54004 Quote Link to comment Share on other sites More sharing options...
mantadoc Posted January 18, 2011 Share Posted January 18, 2011 Has someone got hatchback glass in a coupe or vice versa? Otherwise it should be simple Quote Link to comment Share on other sites More sharing options...
mantapaperman Posted January 18, 2011 Author Share Posted January 18, 2011 (edited) thanks for replys..got the new rubbers gary so thats ruled out! but i,m not sure the glass is correct? anyone know what part numbers they should be? cheers ps..its a coupe gte Edited January 18, 2011 by mantapaperman Quote Link to comment Share on other sites More sharing options...
plumster Posted January 18, 2011 Share Posted January 18, 2011 Favourite is hatch/coupe glass mixed up, the angle of roof & A pillars are slightly different, I speak from experience having only just recently got (thanks Andy R) a clear door glass for my hatch. The coupe one sort of fits but not quite, with gaps as you say either at one point or t'other. Good news is, as long as your'e not on clear glass supply seem to be no problem. Good luck, my passenger door has been whistling to me for about 18 years, it was only when I joined OMOC that I found out why. Quote Link to comment Share on other sites More sharing options...
mantapaperman Posted January 19, 2011 Author Share Posted January 19, 2011 yep think this is the case..the old hatch i have has same part numbers on the front glass as my coupe . however the drivers side is ok? ..think i might swap the regulator and see if that makes any differance? thanks all Quote Link to comment Share on other sites More sharing options...
mantadoc Posted January 19, 2011 Share Posted January 19, 2011 I think I have a set of hatch exclusive green barring the windscreen including the non opening quarters I seem to remember there is adjustment for angle on the runners, including the front runner in / out and on the regulator in the slot where it bolts to the glass and on the holes in the door for the bar that bolts low down to the rear and is a 6" track the back of the scissor runs in. There are also the two top stops, those 10mm bots in the top of the door. I've managed to get both right and wrong glass to fit acceptably in the past. Quote Link to comment Share on other sites More sharing options...
