TJM Posted February 5, 2011 Share Posted February 5, 2011 (edited) Hello I have been approached recently about making some more 5 stud hubs for the Manta/Kadett/Chevette. How many are interested in these, last time I made these they came out at £150 (but would have to confirm with machinist again) a pair and could be tailered to suit your PCD and Spigot diamterer size. I need 7 orders (14 hubs) to make this viable. Please post your interest with required specs below. Regards Tim I already have 1 set required for: Jamie - 5 x 114.3mm (4.5"). Regards Tim Edited February 5, 2011 by TJM Quote Link to comment Share on other sites More sharing options...
Walsall86 Posted February 7, 2011 Share Posted February 7, 2011 (edited) Hi tim I'm interested in a set 5x 112 pcd and 67mm dia centre bore to fit mercedes , these are for an a series if that makes a difference cheers Edited February 7, 2011 by Walsall86 Quote Link to comment Share on other sites More sharing options...
manta356 Posted February 7, 2011 Share Posted February 7, 2011 Hi tim I'm interested in a set 5x 112 pcd and 67mm dia centre bore to fit mercedes , these are for an a series if that makes a difference cheers I'd be interested in a Set of 5 x 120 pcd (a la 400),I'll have to get back to you about the centre bore size. Thanks Paddy Quote Link to comment Share on other sites More sharing options...
manta356 Posted February 8, 2011 Share Posted February 8, 2011 I'd be interested in a Set of 5 x 120 pcd (a la 400),I'll have to get back to you about the centre bore size. Thanks Paddy I just picked up on this from a thread last year about rear 5 stud conversion.Did you ever get any of these made or is there any interest in getting some made. "Remember the hub attachment for knock-on / knock-off wheels on Triumphs, Midgets and Jags? Can't be bothered to draw it but basic idea would be to have something like the above but thicker to allow proper nuts on short studs so about an inch thick and no central hole but with a spigott on the outside to fit BMW wheels and back bored to allow the Manta half shaft spigott to centrally locate. Then a BMW rear disk drops over the BMW / Manta 120 PCD. All those moans people used to have about the Escort rear disks dissappear as there is positive location onto the half shaft and for the disks and wheels. What do you think?" Quote Link to comment Share on other sites More sharing options...
TJM Posted February 12, 2011 Author Share Posted February 12, 2011 Hi Just looking to do the hubs at the moment. Regards Tim Quote Link to comment Share on other sites More sharing options...
TJM Posted February 15, 2011 Author Share Posted February 15, 2011 Hello to all So we have 3 orders as above: Jamie - 5 x 114.3mm (4.5"). Paddy - 5 x 120mm centre bore to follow. Walsall86 - 5 x 112mm (maybe to tight if you want the rear disc mounting as standard, will have to confim), centre bore to follow. I am expecting another order for 4 hubs tomorrow. I need 1 more pair to be ordered then I will make up the rest and hold in stock. Price is confirmed at £150 a pair. Studs will also be required at £8.00 for 8 (12mm x 1.5mm pitch). I will need payment in full and then approx 2-3 weeks after to make. P&P to UK Mainland £11.75. Regards Tim Quote Link to comment Share on other sites More sharing options...
Walsall86 Posted February 16, 2011 Share Posted February 16, 2011 Hi tim I will be using an aftermarket caliper on my hubs so I'm not too worried about the back spacing. Providing you get the required order ammount I can pay next Thursday. Please let me know if that's a problem? Thanks lee Quote Link to comment Share on other sites More sharing options...
TJM Posted February 16, 2011 Author Share Posted February 16, 2011 Hello Lee Are you looking to mount the disc from behind as standard or over the studs at the front? Regards Tim Quote Link to comment Share on other sites More sharing options...
Walsall86 Posted February 16, 2011 Share Posted February 16, 2011 Over the studs would be best as it gives more flexibility for standard discs thanks Quote Link to comment Share on other sites More sharing options...
h0tr0dder_uk Posted February 20, 2011 Share Posted February 20, 2011 I am interested in a set with 5x4.75" pcd. Disc over studs is best for me (is the mounting flange inset more to compensate for disc width?) Quote Link to comment Share on other sites More sharing options...
TJM Posted February 21, 2011 Author Share Posted February 21, 2011 h0tr0dder_uk The mounting flange is in standard offset, no change to compensate for disc thickness, is that okay? Do you also require studs with the hubs £10 for 10? Regards Tim Quote Link to comment Share on other sites More sharing options...
h0tr0dder_uk Posted February 22, 2011 Share Posted February 22, 2011 h0tr0dder_uk The mounting flange is in standard offset, no change to compensate for disc thickness, is that okay? Do you also require studs with the hubs £10 for 10? Regards Tim Spacing is more of an issue for me because of the wheels i want to run. I will be using a brake hat and rotors so can probably mount the hat from behind (possibly using the wheels studs to hold it in place). I will most likely use my own studs but will need the bolt pattern drilled. what would it cost to have it drilled for dual bolt patterns?? (just an option) cheers pete Quote Link to comment Share on other sites More sharing options...
TJM Posted February 22, 2011 Author Share Posted February 22, 2011 Pete Dual bolt pattern should be fine, wouldn't expect there to be extra cost involved, just confirm what you need and I will speak with the machinist. Regards Tim Quote Link to comment Share on other sites More sharing options...
Walsall86 Posted February 22, 2011 Share Posted February 22, 2011 Hi tim just a couple of things regarding my order. Could I have my hubs 5mm shorter so I can mount the discs from the front of the hubs. The centre bore needs to be 66.5mm dia as the wheels are 67mm. The 13mm longer wheel studs will be perfect. The pcd is still 5 x112 think that's all I need. Thanks again Lee Quote Link to comment Share on other sites More sharing options...
TJM Posted February 22, 2011 Author Share Posted February 22, 2011 Lee Is it 5mm shorter on overall width, do you want it removed from the front or rear of the hub? Regards Tim Quote Link to comment Share on other sites More sharing options...
Walsall86 Posted February 23, 2011 Share Posted February 23, 2011 Front of the hub please. Cheers Quote Link to comment Share on other sites More sharing options...
TJM Posted February 23, 2011 Author Share Posted February 23, 2011 Walsall 86 To confirm the flange will remain in the same place on the hub but 5mm will be removed from the front of the hub where the dust cap sits? If this is yes I will go ahead, let me know asap. Regards Tim Quote Link to comment Share on other sites More sharing options...
Walsall86 Posted February 24, 2011 Share Posted February 24, 2011 Hi tim the flange will need to move back 5mm if possible so the disc/wheel will mount 5mm towards the centre of the car. Let me know if that causes any issues? Cheers Quote Link to comment Share on other sites More sharing options...
TJM Posted February 24, 2011 Author Share Posted February 24, 2011 (edited) Lee and hotrodder I have talked to the machinist and he will move the flange 5mm further back into the hub at no extra charge so happy days. Just need to get everyones payment in now and we can get these started by 12 March 11 and should be finished 2-3 weeks thereafter. Regards Tim Edited February 24, 2011 by TJM Quote Link to comment Share on other sites More sharing options...
TJM Posted March 20, 2011 Author Share Posted March 20, 2011 Hello to all Talked to the machinist yesterday, you are looking at 2 weeks and these hubs should be made. Regards Tim Quote Link to comment Share on other sites More sharing options...
manta356 Posted March 21, 2011 Share Posted March 21, 2011 Hi Tim I'm still interested in a Pair of 5 X 120 pcd,I never did measure the Bore but it would be Manta 400 size.I've also got some 5 stud BMW rims which I think have a Bore size of 72mm How do I go about paying. You can let me know by PM if you want to Confirm price and how to pay. Thanks Paddy Quote Link to comment Share on other sites More sharing options...
TJM Posted March 26, 2011 Author Share Posted March 26, 2011 Hello Paddy The billets have been bought and machining started so won't be able to add to the order. I am getting 2 pairs of extra hubs made for stock which are 5x120 with 70mm bore. Any use to you? If yes then you can pay using PayPal at sales@tjmotorsport.co.uk. Price £150 plus £10 for studs and £11.75 P&P to UK Mainland. If need them delivered somewhere else please let me know and I will confrim P&P by next Saturday as I am away until then. Regards Tim Quote Link to comment Share on other sites More sharing options...
manta356 Posted March 26, 2011 Share Posted March 26, 2011 (edited) Double post Edited March 26, 2011 by manta356 Quote Link to comment Share on other sites More sharing options...
manta356 Posted March 26, 2011 Share Posted March 26, 2011 (edited) Hello Paddy The billets have been bought and machining started so won't be able to add to the order. I am getting 2 pairs of extra hubs made for stock which are 5x120 with 70mm bore. Any use to you? If yes then you can pay using PayPal at sales@tjmotorsport.co.uk. Price £150 plus £10 for studs and £11.75 P&P to UK Mainland. If need them delivered somewhere else please let me know and I will confrim P&P by next Saturday as I am away until then. Regards Tim My name was on the Original list for a set of these 5 x 120 pcd hubs anyway,but i never got a request for payment.(see posts no.3 and no.6) I'm still interested in these.Can you give me a price for a pair,including studs,delivered to Ireland. Thanks Paddy Edited March 26, 2011 by manta356 Quote Link to comment Share on other sites More sharing options...
TJM Posted March 27, 2011 Author Share Posted March 27, 2011 Hello Paddy I am sure I PM'd you reference whether you still wanted the hubs when I was ready to place the order. If I missed you out apologies. A pair of hubs (5x120, 70mm spigot) with studs (+13 or +25mm, let me know) £182.50 inc delivery. My PayPal is sales@tjmotorsport.co.uk. Regards Tim Quote Link to comment Share on other sites More sharing options...
