611 Posted March 20, 2011 Share Posted March 20, 2011 I have a brand new A Series front bumper left hand side overrider. Very rare, yours for £25 + postage. Quote Link to comment Share on other sites More sharing options...
moodoo Posted March 20, 2011 Share Posted March 20, 2011 Is that definitely a Manta A-series one? Is it an Ascona one? I'm pretty sure the 'tail' portion on the ones on my Manta (for which I need a replacement LH side one), are longer than that? Quote Link to comment Share on other sites More sharing options...
611 Posted March 20, 2011 Author Share Posted March 20, 2011 As far as i know its for a manta, the part no on it is 3459463, i dont know much about Ascona's so not sure how you tell? When you say the tail, do you mean the metal part that come out of the bottom where you bolt it on? if so its about 1 1/2 inches from the bend to the bottom. Let me know if there are any other measurements you need or more pictures. Andy Quote Link to comment Share on other sites More sharing options...
moodoo Posted March 21, 2011 Share Posted March 21, 2011 I'm no expert either Andy, but the rubber 'tail', where the metal tab is attached (as well as the metal tab itself), seems longer than on the one you have. If you look at the picture here for instance, you can just about make it out. http://www.mantaclub.org/archive/manta_a_sr.htm I could be comepletely wrong though - but I'll have a look at mine this evening and see. Quote Link to comment Share on other sites More sharing options...
moodoo Posted March 22, 2011 Share Posted March 22, 2011 Andy, Looked at mine this evening, and they are definitely not the same as yours. Mine have a longest dimension of around 275mm (rubber part only, nose to tail), and the metal tab is around 70mm long. Mine follow the line of the curved front valence quite well, yours looks much more 'upright'. Still doesn't help you with what yours fits mind...I had a look on dr-mantas site, and it does look a bit like the ones he has marked as Ascona. Fin Quote Link to comment Share on other sites More sharing options...
611 Posted March 22, 2011 Author Share Posted March 22, 2011 Hi Fin Looking at the pictures your right the manta one does look much longer so it must be an Ascona one, does yours have a part number on the back? i got a list off of Mark Kinnon (who has done loads of stuff for manta A's) and the list shows this for the part number under the manta info: N/S Front Bumper Overider (Rubber) 17 52 624 03459463 So i am total confused! maybe someone with and Ascona can shed some light on it? Sorry i cant help you out. If you need any front suspension upper bushes i have some of those im going to put up on the site in the next day or two when i have images, and they definatly are off a Manta!! Thanks Andy Quote Link to comment Share on other sites More sharing options...
paul1393 Posted March 24, 2011 Share Posted March 24, 2011 Your overrider is for an Ascona A.! GM part numbers begining with 0343.... and 0345.... nearly always relate to Manta/Ascona A. Early Manta/Ascona "B" GM part number began 0928.... Numbers did get superceeded quite often, which was very confusing if you were trying to identify a part by the number stamped on it.....I'll put my anorak back on the peg now! Quote Link to comment Share on other sites More sharing options...
611 Posted March 24, 2011 Author Share Posted March 24, 2011 Hey Paul Glad you had your anorak with you! Thanks for the info, just need to find someone with an Ascona now that needs one! Need to pay for all the new bits im getting as its all starting to get expensive! Andy Quote Link to comment Share on other sites More sharing options...
