Shug Posted April 5, 2011 Share Posted April 5, 2011 Anyone got a pair lying around? Have some clearance issues on my A on the rear wheels (13" with standard tyres!) and want to compare ride height on standard compared with lowering springs I have on (not sure they are right) Link to comment Share on other sites More sharing options...
1900SR Posted April 5, 2011 Share Posted April 5, 2011 Are they standard Manta A wheels you've got with the original back axle? Only ask as my car runs a B back axle and it just clears, so a standard A axle shoud have plenty of room, unless your wheels have a different offset. Link to comment Share on other sites More sharing options...
Shug Posted April 5, 2011 Author Share Posted April 5, 2011 (edited) They're 6" wide ats wheels et30 with 185/70/13 on original axle. Lowered 30mm and the arches are sitting on the tyres. With 185/60/13 rostyles 5.5" (dunno offset) they sit inside the arch. Edited April 5, 2011 by Shug Link to comment Share on other sites More sharing options...
upk Posted April 5, 2011 Share Posted April 5, 2011 (edited) Shug I ran 7.5 wide by 15inch with 195 X50 tyres and i am sure et was 25 on my A with lowered springs no problem. See if the sites on this link help:- http://forums.mantaclub.org/topic/27709-off-set-and-wheel-dia-calculator/page__pid__195313#entry195313 by my reckoning that means my overall wheel diameter was 576mm compared to your 589mm, so that means your effective wheel diameter is 13mm more than mine. And my offset was 24mm further out than yours meaning you probably have a manta B back axle on your motor ( as my tyres sat nicely inside the arch). Kev Edited April 5, 2011 by upk Link to comment Share on other sites More sharing options...
Shug Posted April 5, 2011 Author Share Posted April 5, 2011 How wide is a b axle? Will measure mine. No reason to believe it is as car was off road since 94, have practically every reciept and service note and no mention of the axle. Not to say it wasn't swapped tho. Tis all a bit weird... Link to comment Share on other sites More sharing options...
rayman Posted April 5, 2011 Share Posted April 5, 2011 Hi Shug ,ive got 15"alloys with 185x55 and they are 7"wide et35 along with a 40mm spring drop and still had to put 10mm spacer on to make it fill the arch Link to comment Share on other sites More sharing options...
Shug Posted April 5, 2011 Author Share Posted April 5, 2011 (edited) Here's the rear wheel: Inner lip of wheel arch is pressing on tyre. And the front for comparison: Edited April 5, 2011 by Shug Link to comment Share on other sites More sharing options...
Johan Posted April 5, 2011 Share Posted April 5, 2011 i think you have a manta b axle on your manta a that is on both sides 3,5 cm wider Link to comment Share on other sites More sharing options...
Shug Posted April 6, 2011 Author Share Posted April 6, 2011 Tyres need replaced anyway, so I suppose I could use 175 tyres and roll the rear arches. Everytime I get closer to completion some stupid wee problem that consumes a ridiculous amount of time pops up Link to comment Share on other sites More sharing options...
bhp Posted April 6, 2011 Share Posted April 6, 2011 Hope i'm not teaching you to suck eggs but, if you have the standard panhard rod on it will push the axel over to one side when you lower the car & i agree the clearence looks like you've got a manta B axel???? Hope you sort it out, All the best, bhp...... Link to comment Share on other sites More sharing options...
rayman Posted April 6, 2011 Share Posted April 6, 2011 Shame your so far away as i could lend you my standard springs to try.Dont think even the northwest pony express could get em that far but you never know ? Link to comment Share on other sites More sharing options...
Shug Posted April 7, 2011 Author Share Posted April 7, 2011 Hope i'm not teaching you to suck eggs but, if you have the standard panhard rod on it will push the axel over to one side when you lower the car & i agree the clearence looks like you've got a manta B axel???? Hope you sort it out, All the best, bhp...... I did think on that, but its the same both sides. Have a spare panhard rod but it got bent (digger mishap!) Might get it straightened and shortened. Any ideas how much shorter it needs to me? My trigonometrys a little rusty! Link to comment Share on other sites More sharing options...
johnboy Posted April 7, 2011 Share Posted April 7, 2011 If you have an even wheel spacing on both sides (ie; both wheels rubbing the arches) then shortening the panhard rod will only push the axle even further into the n/s arch. I can take some measurements from my a axle if you want to check it, i'm running tsw 7.5 by 17 with 205/40 tyres, dont know the et sorry, there bloody close but dont touch or rub even with some enthusiastic(ahem) driving Link to comment Share on other sites More sharing options...
