Rapierdave Posted April 27, 2011 Share Posted April 27, 2011 Does any know where to get a propshaft centre bearing for a Manta B, mine is very noisy. Link to comment Share on other sites More sharing options...
paulmanta Posted April 28, 2011 Share Posted April 28, 2011 They are a common bearing size available from most bearing suppliers off the shelf for under a tenner, just remove the rubber donut thing and take out the bearing in the little carrier, then take the carrier apart and you will see the bearing, numbers on the bearing will ID it to a bearing shop. PS: the carrier is two halves of pressed metal that are a simple push together fit. Clean off the dirt and you will see the split line, a bit of wiggling/levering with a tiny flat blade normally splits these apart. Link to comment Share on other sites More sharing options...
Rapierdave Posted April 28, 2011 Author Share Posted April 28, 2011 Thanks Paul I was hoping they were a common bearing still available. Link to comment Share on other sites More sharing options...
alymac Posted April 28, 2011 Share Posted April 28, 2011 (edited) think its just a 6205 2zz, but i would fit a 6205 2rs just has rubber sheilds, standard bearing dead easy to get around £4 might even have one here! Edited April 28, 2011 by alymac Link to comment Share on other sites More sharing options...
