Tips On Refitting Front Springs Without Scratchin Em
steel
spending a bit refurbing the front crossmember and ftting spax suspension years ago i did similaire and i seem to remember scratching the springs to hell refitting them, any tips from you lads on best way of doing it
you could use masking tape and remove after , but Phil is correct ,aftermarket uprated or lowered springs are usually an easy fit
Edited by pat
Just done mine after painting crossmember with minus 40s and managed to get them in with the aid of a large ratchet strap with a hook on one end which i put onto bottom wishbone near ball joint and pulled it up to get shock in to hold it all together :thumbup
