BMD Posted June 20, 2011 Share Posted June 20, 2011 as above lads/ladesses! need a stalk for my '88 gte manta.... cheers billy Link to comment Share on other sites More sharing options...
Julian Posted June 20, 2011 Share Posted June 20, 2011 as above lads/ladesses! need a stalk for my '88 gte manta.... cheers billy Do you mean the Indicator/wiper stalk, if so is it the same as the early B? Link to comment Share on other sites More sharing options...
BMD Posted June 20, 2011 Author Share Posted June 20, 2011 hi m8 and thanks for the reply tbh m8 i'm not 100% sure if the early ones and last ones shared the same stalk, i'm sure somebody on here will know...it does the indicators and wipers, cheers Link to comment Share on other sites More sharing options...
Julian Posted June 20, 2011 Share Posted June 20, 2011 hi m8 and thanks for the reply tbh m8 i'm not 100% sure if the early ones and last ones shared the same stalk, i'm sure somebody on here will know...it does the indicators and wipers, cheers Can someone let us know if they are compatible, Please. Link to comment Share on other sites More sharing options...
paulmanta Posted June 20, 2011 Share Posted June 20, 2011 They are all the same right from Mk1 cavs through /ascona B and right up to the last manta ever made. I assume you need the whole lot, the entire assembly ? if so you need to remove the steering wheel to change the assembly, this assembly includes the upper steering bearing, horn, indicators, wipers and washers, also the hazard switch. Is held on with 3 10mm bolts. How quickly do you need one ? I have one on a car but it might take a day or so to get it off, I will be at Billing if you want to wait till then to collect. Link to comment Share on other sites More sharing options...
BMD Posted June 20, 2011 Author Share Posted June 20, 2011 paul many thanks for the info m8 i'm not in a massive hurry tbh, as it looks like i'm keeping the motor, thought i'd put right the couple of wee niggles, one of which is a tendency for the indicators/lights to go funny if i select full-beam; i presume its a faulty switch, or do you know if anything else could be causing it? if not, i need the switch, cheers lads... billy Link to comment Share on other sites More sharing options...
paul691 Posted June 22, 2011 Share Posted June 22, 2011 ive got one here: http://forums.mantaclub.org/topic/28859-parts-clearout/ Link to comment Share on other sites More sharing options...
