brianm Posted July 16, 2011 Share Posted July 16, 2011 can any one tell me how mant splines the clutch has ,gertrag 5 speed to 1.8e engine ,its a 1984 ,save me splitting the engine and box to find out ,cause its buried at the back off the garage !!! thanks brian Quote Link to comment Share on other sites More sharing options...
dynamytedan Posted July 16, 2011 Share Posted July 16, 2011 (edited) im prety sure its 14 splines for a 1800 manta berlinetta (1.8s) gearbox shaft/clutch friction plate so you could use a calibra turbo clutch and standard 1800 clutch bearing with a pot type flywheel if you want a stronger clutch . Edited July 16, 2011 by dynamytedan Quote Link to comment Share on other sites More sharing options...
mantasrme Posted July 16, 2011 Share Posted July 16, 2011 Yeah 14 splines 25mm diameter for the centre Quote Link to comment Share on other sites More sharing options...
brianm Posted July 16, 2011 Author Share Posted July 16, 2011 thanks lads ,will be able to order one without having empty the garage :D Quote Link to comment Share on other sites More sharing options...
