dog321fish Posted August 12, 2011 Share Posted August 12, 2011 (edited) Hi I think the cooling system holds 12 pints of fluid? Should this be 8pts of water and 4pts of Antifreeze? or should it be a 50/50 mix? The car will be in an unheated lock-up over the winter. Obviously we do not know how severe this winter will be! Any particular brand of Anti-freeze to recommend? Cheers Dave Edited August 12, 2011 by dog321fish Quote Link to comment Share on other sites More sharing options...
cam.in.head Posted August 12, 2011 Share Posted August 12, 2011 all very much a matter of personal preference. i have always tried to use bluecol (blue) rather than red .& replaced every 3 years. a 1/3 mix should be fine .although a 50/50 would be the absolute best. Quote Link to comment Share on other sites More sharing options...
biffy1984 Posted August 12, 2011 Share Posted August 12, 2011 I also use bluecol and would mix it roughly 30 percent antifreeze. Pretty sure at 30 percent it can withstand up to -40 odd degrees. Cheers Peter. Quote Link to comment Share on other sites More sharing options...
discodas Posted August 12, 2011 Share Posted August 12, 2011 We recently changed as part of a overhaul, and used Unipart's bluecol, poured almost all the 5l prior to topping up with water. So not sure what the actual ratio is but all seams fine. Have tested with a hydrometer and it reads -58 so I think the ratio is approx 59% anti freeze and 41% water?? Darryl Quote Link to comment Share on other sites More sharing options...
dog321fish Posted August 12, 2011 Author Share Posted August 12, 2011 (edited) Thanks all Bluecol it is! Cheers Dave Edited August 12, 2011 by dog321fish Quote Link to comment Share on other sites More sharing options...
lamchop77 Posted August 13, 2011 Share Posted August 13, 2011 Hi I think the cooling system holds 12 pints of fluid? Should this be 8pts of water and 4pts of Antifreeze? or should it be a 50/50 mix? The car will be in an unheated lock-up over the winter. Obviously we do not know how severe this winter will be! Any particular brand of Anti-freeze to recommend? Cheers Dave Always used the blue stuff myself, never the red but thats prob cos my dad never did, been told the new pink coloured stuff is for full alloy engines and is designed to be changed less frequently. Another thing is i was reading up on antifreeze mixes as i was told by someone that a stronger mix gives better cooling. Came across an article on the web ( just put in search of anti freeze mix ratio ) was actually about light aircraft engines but they are virtually the same. One guy was running 50/50 mix (i think) and had problems with high running temps, they reduced the mix and to about 25% and dropped the running temps by about 15 degrees. The outcome is run as little as you can for the best cooling, anti freeze is thicker and its cooling properties are not as good as pure water. Worth a read if you can find it. HTH Chris Quote Link to comment Share on other sites More sharing options...
