GMC Posted September 7, 2011 Share Posted September 7, 2011 (edited) Hi all, Having removed the XE donor engine about 5 years ago I'm needing a wee refresher where all the inlet manifold pipework goes.......... Stepper motor pipework....... From memory, the short hose connects onto here.................the outlet on the bottom of the inlet manifold If that is correct, where does the long hose connect too?? Water pipework........ These 2 small bore pipes come from the 3 way coupling under the inlet throttle body. The short pipe connects onto the brass hose tail where the manifold connects to the head. The long pipe presumably needs to connect to the main water pipework somewhere? If it does I was planning to extend it and 'T' it into the radiator top hose. Is this right?? 3 way coupling........(under the inlet throttle body) Out if interest, what does this do.....it appears to have 2 water connects (on the sides) and 1 oil breather (in the middle?) Edited September 7, 2011 by GMC Quote Link to comment Share on other sites More sharing options...
mantasrme Posted September 7, 2011 Share Posted September 7, 2011 The long pipe from the stepper motor goes to the back of the air-box or power cap, short pipe goes to back of inlet manifold as you say. Can't help with the water pipe as i modified 1.8 pipes for mine Quote Link to comment Share on other sites More sharing options...
GMC Posted September 7, 2011 Author Share Posted September 7, 2011 The long pipe from the stepper motor goes to the back of the air-box or power cap, short pipe goes to back of inlet manifold as you say. Can't help with the water pipe as i modified 1.8 pipes for mine Thanks Mantame, I hadn't fitted my airbox yet, thats why I couldn't fine a home for it! Anyone one else got info on the small water pipe & 3 way coupling Quote Link to comment Share on other sites More sharing options...
upk Posted September 7, 2011 Share Posted September 7, 2011 (edited) i installed a header tank when i did the A series but you could go straight to the rad with it! (i did use jenvey throttle bodies so no need for a water cooled manifold). Edited September 7, 2011 by upk Quote Link to comment Share on other sites More sharing options...
