Starting Problems
Manta again
examine carefully the connection on the 6mm wire on the solenoid.this is on the same large terminal as the pos battery lead.it sends power to everything inside the car.(fusebox,ignition switch)if this terminal is not 100% it can cause intermittent loss of power to all circuits & sometimes make the ign lamp glow .if in doubt run an extra wire from this terminal & join it to the PERMANENT live on the connector that the ign switch plugs into.
  • Replies 50
  • Created
  • Last Reply
Top Posters In This Topic
